HAL.VMAN.AddPortUpdtSVIDFail
Description
An internal software error has occured while updating a translated port with a new translated SVID to a VMAN. This indicates that the translated port has not been updated correctly to the VMAN and the translated port may not function properly.
Remedy
Delete and readd the translated port with the new SVID to the VMAN. If the problem persists, Increase the log severity level of HAL.VMAN and report this problem to the customer support with the output of "show log" command.
Severity
Error
Message Text
Failed to add the port while updating the translated SVID %vmanxsvid% for the port %slot%:%port% in VMAN %vmanname%
Message Parameters
Name Type
slot Slot
port Port
vmanxsvid VLAN-tag
vmanname String
