The specified PBB Tunnel message could not be constructed and sent to one or more I/O Modules due to event buffer allocation failure. This will result in incorrect programming of hardware tables and will impact forwarding of IEEE 802.1ah conformant traffic.
The system is low on memory resources. The configuration should be reduced in scale or complexity in order for the system to continue operating correctly.
Critical
Failed to allocate event buffer for message %info%
| Name | Type |
| info | String |
Print
this page
Email this topic
Feedback
