Constructing the Egress Mod-Port Type generic port based on slot number and port number has failed. This may be caused when the system is not able to get generic port number for specified physical port.
Ensure that correct port number is passed. Unconfigure WRED. Reboot the switch. Repeat WRED configuration steps. If the problem persists after reboot, collect show tech output and contact technical support with suitable information.
Error
Failed to extract Modport type generic port for physical port %port% with Error: %errormsg%
| Name | Type |
| port | String |
| errormsg | String |
Print
this page
Email this topic
Feedback
