FEFI mode enabled for ports set in the 64 bit port Map. If there are any errors, error will be non zero and bit set will indicate that the corresponding port did not have FEFI enabled.
There is no remedy because there is no problem to be resolved.
Debug-Data
FEFI mode enabled in batch for port map %fefiPortMap% error %errorCode%
| Name | Type |
| fefiPortMap | xInt64 |
| errorCode | xInt64 |
Print
this page
Email this topic
Feedback
