This situation occurs when we try to extract the buffer pool configuration from an invalid port number on a specific slot.
Appropriate value of port number should be passed in order to retrieve buffer pool configuration. Collect data from 'show tech' command and contact technical support with suitable information.
Error
%funct%: Failed to extract buffer pool configuration due to invalid port number %port%
Name | Type |
funct | String |
port | String |
