An unsupported and unlicensed high speed transceiver has been detected, and the '3rd Party Optics' feature license has not been installed. The trial period for unlicensed high speed transceivers has begun, after which all unlicensed high speed transceivers will be restricted to 25 percent of capacity.
Use supported transceivers instead. Otherwise, contact technical support to purchase and install a '3rd Party Optics' feature license. Issue the CLI command 'show port x transceiver information detail' to see the transceiver type, vendor, part number, etc.
Warning
An unlicensed high speed transceiver has been detected and the %trial_days% day trial period for all unlicensed high speed transceivers has begun.
| Name | Type |
| trial_days | uInt |
Print
this page
Email this topic
Feedback
