HAL.FDB.GetVLANInfoFailed
Description
HAL needs to get detailed VLAN information before it can add the static FDB entry for the VLAN. However, something went wrong and it failed to get the VLAN information.
Remedy
Delete the vlan and add the vlan again. If this fails, reboot the box.
Severity
Error
Message Text
Getting VLAN info has failed while adding static FDB entry for vlan %vlanId%
Message Parameters
Name Type
vlanId VLAN-tag
