An unsupported high speed transceiver is attached to a port, and the '3rd Party Optics' feature license has not been installed. The transceiver bandwidth has been restricted.
Use a supported transceiver instead. Otherwise, contact technical support to purchase and install a '3rd Party Optics' feature license. Issue the CLI command 'show port x transceiver information detail' to see the transceiver type, vendor, part number, etc.
Warning
The transceiver attached to port %slo_po% is unsupported and unlicensed. The transceiver has been restricted to %restrict_val%.
| Name | Type |
| slo_po | SlotPort |
| restrict_val | String |
Print
this page
Email this topic
Feedback
