HAL.VSM.RepairFiltFail
Description
This log indicates that an attempt to repair the specified egress blocking filter failed after a node failover. The specified return code value is provided by the low level driver which has only internal significance.
Remedy
This is an unexpected internal condition needing technical assistance. Contact technical support with the following information: - output of "show tech"
Severity
Error
Message Text
Failed to repair egress block filter on slot %slot%, unit %unit% return code %rv%
Message Parameters
Name Type
slot uInt
unit uInt
rv uInt
