Clearing per QoS TX statistics for a port failed on hardware.
This problem is usually due to a failure of accessing a hardware register. The hardware may be in a bad state. The error message gives the detail of the failure. The problem usually can be resolved by retrying the operation or power-cycling the switch or the card in the slot.
Error
Failed to clear per QoS TX statistics for port %slotPort%: %errMsg%
Name | Type |
slotPort | SlotPort |
errMsg | String |
