HAL.PBB.RemBVLANFromISIDPSIFail
Description
The message indicates the failure in removing a Provider VLAN from the floodin group of the VLAN or the I-SID. Lower the severity to narrow the cause of failures. The cause could be in the PSI library or the low on memory in the system.
Remedy
Retry the configuration so that the ports are re-deleted from the flooding group of I-SID or VLAN.
Severity
Debug-Summary
Message Text
Failed to remove PNP ports in VLAN %vlanName% from PSI of I-SID %isidName% when %info%.
Message Parameters
Name Type
vlanName String
isidName String
info String
Applicable Platforms
  • I386 virtual machine switch simulator
