ExtLibA.SockLib.InitFail
Description
Sockets Interface failed to initialize correctly.
Remedy
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Severity
Warning
Message Text
The Sockets interface failed to initialize correctly.
