HAL.Card.MasterVersionFailed
Description
An abnormal condition has been detected which, although it is not interfering with the normal operation of the system, may signal that the system or the network in general may not be functioning as expected. The condition may have been caused by an unusual or unexpected circumstance related to some external stimulus.
Remedy
The exact remedy is dependant on the particular situation; but the condition may be resolved by retrying the operation when the resource becomes available.
Severity
Warning
Message Text
A request to get the version code of the management module in slot %slotNum% with assigned ip address of %slotIp% failed - returning a completion code of %return_code% .
Message Parameters
Name Type
return_code sInt
slotNum uInt32
slotIp srcIPaddress
