An internal software error has occured while adding a port with a translated SVID to a VMAN. This indicates that the translated port has not been added correctly to the VMAN and the translated port may not function properly.
Delete and readd the translated port to the VMAN. If the problem persists, Increase the log severity level of HAL.VMAN and report this problem to the customer support with the output of "show log" command.
Error
Failed to add translated SVID %vmanxsvid% for the port %slot%:%port% in VMAN %vmanname%
Name | Type |
slot | Slot |
port | Port |
vmanxsvid | VLAN-tag |
vmanname | String |
