HAL.WRED.GetQueEstBufSizFail
Description
The configured Buffer Pool Size for the Port's Queue from H/W is read to calculate the buffer size that would be used. This error message states that retrieval of buffer parameters for port range instance has failed. This may occur when incorrect unit number is passed.
Remedy
Appropriate value of unit number should be passed in order to retrieve queue's buffer parameters. Collect show tech output and contact technical support with suitable information.
Severity
Error
Message Text
%funct%: Failed to get queue's buffer parameters for port %port% with retCode %retCode%
Message Parameters
Name Type
funct String
port String
retCode uInt32
