HAL.LAG.CfgNoUcastHashFail
Description
Configuring the link aggregation group's hash algorithm for non-unicast packets failed in hardware on a chip of a card.
Remedy
This problem is usually due to a failure of accessing a hardware register. The hardware may be in a bad state. The error message gives the detail of the failure. The problem usually can be resolved by retrying the operation or power-cycling the switch or the card in the slot.
Severity
Error
Message Text
Failed to configure hash algorithm for non-unicast packets for link aggregation groups on slot %slot% unit %unit%: %errMsg%
Message Parameters
Name Type
slot Slot
unit sInt32
errMsg String
