HAL.Card.ExtTblClbrtDataInv
Description
The external-table hardware interface calibration data is invalid or missing for this Summit switch or BD8K interface card. This hardware interface is calibrated when the switch or card is manufactured. Without this data, the external table cannot be used reliably for L2, L3 or ACL lookups.
Remedy
Re-calibrate the switch or card from EXOS. This can be done with the following command: debug hal run external-table calibration. This command will cause a re-calibration of the external-table hardware interface for the switch or card. This process will take 15-30 minutes and will involve a reboot. Please do not disconnect power during this process.
Severity
Error
Message Text
%slotName% has invalid or missing external-table calibration data.
Message Parameters
Name Type
slotName String
