This message could not be packaged to be sent over the conduit infrastructure between the MM and the I/O blade. This could be due to backlog of messages between the MM and the I/O slots.
Replay any config that may be failing or reset the I/O slot. If the MM is running low on resources, it may need to be rebooted.
Error
Error while packing data to be sent over conduit to I/O. Context: %context%
Name | Type |
context | String |
