The slave join to a Routing Protocol Manager has gone. Either the RPM deleted the join, or the join failed (in which case there has already been a "join failed" log. The RPM will no longer receive redistributed routes. RPM routes will not be added to the routing table.
No action required - Informational message only.
Info
RTMgr stub RPI join to RPM (PID = %p1%) has gone.
Name | Type |
p1 | uInt32 |
