Clearing statistics for all ports in a slot failed on hardware.
This problem is usually due to a failure of accessing a hardware register. The hardware may be in a bad state. The error message gives the detail of the failure. The problem usually can be resolved by retrying the operation or power-cycling the switch or the card in the slot.
Error
Failed to clear statistics for all ports in slot %slot%: %errMsg%
| Name | Type |
| slot | Slot |
| errMsg | String |
Print
this page
Email this topic
Feedback
