An instance replication operation failed. The instance may be disrupted if System Manager fails over.
Investigate the cause of the replication failure. If this does not solve the problem, contact support.
Error
An instance replication operation failed. Replication action = %p1% Replication return code = %p2% Entity type = %p3% Entity index = %p4% Instance index = %p5%
Name | Type |
p1 | uInt8 |
p2 | uInt8 |
p3 | xInt32 |
p4 | HexByteArray |
p5 | xInt32 |
