HAL.PBB.IndxMisMatch
Description
A received index of the displayed type did not match with the index currently in the PBB Tunnel Database. This is unexpected and can indicate that the standby MM is out of sync with the active MM.
Remedy
Reboot of the standby MM might fix the issue. If the problem persists, contact Extreme Customer support with details of the error message
Severity
Warning
Message Text
%type% mismatch - Received Index %rcvidx% Current Index %curridx%
Message Parameters
Name Type
type String
rcvidx uInt16
curridx uInt
Applicable Platforms
  • I386 virtual machine switch simulator
