HAL.MPLS.ProcMsgVerInv
Description
An unsupported version number was used when constructing or processing a message used for communication with the I/O Modules.
Remedy
This may be a symptom of version incompatibility between the MM and one or more of the I/O Modules. Ensure the software versions are compatible. The I/O Module may require a reboot (disable/enable).
Severity
Critical
Message Text
Message version %version% unsupported.
Message Parameters
Name Type
version uInt
