HAL.OAM.DelHwMEPFail
Description
This message is generated when an attempt to delete a maintenance domain fails because no no entry can be found in the database with the given MAID, level, VLAN id, MEP id, and port.
Remedy
Verify the correct parameters are specified on the command line. Note the MAID must match on the type originally used. You can also verify the HAL OAM database with the command: debug hal show platform hwa-oam all
Severity
Error
Message Text
Failure attempting to delete maintenance endpoint in Hardware Accelerated CFM: T=%type% L=%level% V=%vlanid% I=%mepid% P=%portid%
Message Parameters
Name Type
type String
level uInt
vlanid uInt
mepid uInt
portid uInt32
