ExtLibA.RtMgr.StrtExtRtUpdtFail
Description
Failed to start external route update transaction with RTMgr. If this is an add or update transaction then routes will not be updated correctly. If this is a delete transaction then invalid routes might remain in FIB.
Remedy
Look at logs for any error message from RTMgr. Try to disable export and enable it again.
Severity
Error
Message Text
Failed to start external route %p1% transaction, origin code=%p2%, client ID %p3% %p4% %p5% %p6%
Message Parameters
Name Type
p1 String
p2 sInt
p3 xInt32
p4 uInt32
p5 uInt16
p6 uInt8
