HAL.Transceiver.TrialExp
Description
The trial period for unsupported and unlicensed high speed transceivers has expired, and the '3rd Party Optics' feature license has not been installed. All unlicensed high speed transceivers will be restricted to 25 percent of capacity the next time the respective port(s) is/are enabled.
Remedy
Use supported transceivers instead. Otherwise, contact technical support to purchase and install a '3rd Party Optics' feature license. Issue the CLI command 'show port x transceiver information detail' to see the transceiver type, vendor, part number, etc.
Severity
Warning
Message Text
The %trial_days% day trial period for unsupported and unlicensed high speed transceivers has expired. Unlicensed high speed transceivers will be restricted to 25 percent of capacity the next time the respective port(s) is/are enabled.
Message Parameters
Name Type
trial_days uInt
