HAL.Mirror.AllocVLANDisblFail
Description
When trying to send asynchronous conduit message for mirroring, HAL conduit did not return OK.
Remedy
Try to disable mirroring and re-enable it.
Severity
Debug-Data
Message Text
Failed to allocate size %size% when sending conduit message for disable learning on remote VLAN.
Message Parameters
Name Type
size uInt
Applicable Platforms
  • I386 virtual machine switch simulator
