HAL.OAM.DelHwMDFail
Description
This message is generated when an attempt to delete a maintenance domain fails because no no entry can be found in the database with the level and VLAN.
Remedy
Verify the correct parameters are specified on the command line. You can also verify the HAL OAM database with the command: debug hal show platform hwa-oam all
Severity
Error
Message Text
Failure deleting the maintenance domain because it cannot be found in the database.
