The message indicates the failure in removing a Provider Networ port from the flood group of I-SID. Lower the severity to narrow the cause of failures. The cause could be in the PSI library, the conduit pipe to the given slot, or the low on memory in the system.
Retry the configuration so that the ports are re-deleted from flood group of the I-SID.
Debug-Summary
Failed to add a port %slot%:%port% in VLAN %vlanName% associated to I-SID %isidName%.
Name | Type |
slot | Slot |
port | Port |
vlanName | String |
isidName | String |
