An optic module of a particular type has been inserted into a port on this platform with which it is not compatible. The optic module can not and will not work in the specified port.
Remove the incompatible optic from the port and replace it with one that is supported in that port.
Warning
The %optic% optic module is not compatible with this port on this platform - please remove it from port %slotPort%.
Name | Type |
optic | String |
slotPort | SlotPort |
