HAL.OAM.ClearHwMAFaultsFail
Description
This message is generated when an attempt to clear the fault indicators for a maintenance association fails because a matching entry cannot be found in the databsae.
Remedy
Verify the correct parameters are specified on the command line. Note the MAID must match on the type originally used. You can also verify the HAL OAM database with the command: debug hal show platform hwa-oam all
Severity
Error
Message Text
Failure attempting to clear maintenance association faults in Hardware Accelerated CFM: L=%level% V=%vlanid%
Message Parameters
Name Type
level uInt
vlanid uInt
