An unsupported version number was used when processing the displayed message used for communcation with the I/O Modules. This may be a symptom of version incompatibility between the MM and one or more of the I/O Modules.
Ensure the software versions are compatible. The I/O Module may require a reboot (disable/enable)
Warning
Unsupported version %ver% in %msg% message
Name | Type |
msg | String |
ver | uInt8 |
