HAL.PBB.AddCNPToPSIFail
Description
The message indicates the failure in adding a Customer Networ port to the flood group of I-SID. Lower the severity to narrow the cause of failures. The cause could be in the PSI library, the conduit pipe to the given slot, or the low on memory in the system.
Remedy
Retry the configuration so that the ports are re-added to the flood group of I-SID.
Severity
Debug-Summary
Message Text
Failed to add a port %slot%:%port% in VLAN %vlanName% to I-SID %isidName%.
Message Parameters
Name Type
slot Slot
port Port
vlanName String
isidName String
Applicable Platforms
  • I386 virtual machine switch simulator
