When there are operational changes in a trunk (member port goes down or comes up) the status is check-pointed to the backup MM from the master MM. This error indicates an error in such an updation.
Disable and re-enable sharing for the given slot,port.
Warning
Failed to Checkpoint the status information to the backup for the trunk %slot%:%port%
| Name | Type |
| slot | Slot |
| port | Port |
Print
this page
Email this topic
Feedback
