HAL.WRED.ClrStatsInv
Description
This indicates that WRED counters/statistics are not cleared on specified slot.
Remedy
Repeat clearing the WRED statistics. Unconfigure WRED parameters. Reboot the switch. Repeat WRED configuration steps. If problem persists after reboot, collect data from 'show tech' command and contact technical support with suitable information.
Severity
Warning
Message Text
Unable to clear WRED statistics on slot %slot%
Message Parameters
Name Type
slot uInt32
