ExtLibA.EntityMgr.JoinRepOperFail
Description
A join replication operation failed. The join may be lost if System Manager fails over.
Remedy
Investigate the cause of the replication failure. If this does not solve the problem, contact support.
Severity
Error
Message Text
A join replication operation failed. Replication action = %p1% Replication return code = %p2% Master entity type = %p3% Master entity index = %p4% Slave entity type = %p5% Slave entity index = %p6%
Message Parameters
Name Type
p1 uInt8
p2 uInt8
p3 xInt32
p4 HexByteArray
p5 xInt32
p6 HexByteArray
