ExtLibA.EntityMgr.RepLocOperFail
Description
A location replication operation failed. The location may be disrupted if System Manager fails over.
Remedy
Investigate the cause of the replication failure. If this does not solve the problem, contact support.
Severity
Error
Message Text
A location replication operation failed. Replication action = %p1% Replication return code = %p2% Location index = %p3%
Message Parameters
Name Type
p1 uInt8
p2 uInt8
p3 uInt32
