HAL.Transceiver.Trial
Description
An unsupported high speed transceiver is attached to a port, and the '3rd Party Optics' feature license has not been installed. The trial period for unsupported high speed transceivers is active, after which the transceiver will be restricted to 25 percent of capacity.
Remedy
Use a supported transceiver instead. Otherwise, contact technical support to purchase and install a '3rd Party Optics' feature license. Issue the CLI command 'show port x transceiver information detail' to see the transceiver type, vendor, part number, etc.
Severity
Warning
Message Text
The transceiver which has been attached to port %slo_po% is unsupported and unlicensed. The %trial_days% day trial period for unsupported high speed transceivers has %days_left% remaining.
Message Parameters
Name Type
slo_po SlotPort
days_left String
trial_days uInt
