HAL.PBB.MaxTunlRch
Description
Create of PBB Tunnel failed as the number of PBB tunnels has reached the maximum supported limit. Please refer to EXOS documentation on supported limits on PBB tunnels for this release. Due to this limit being reached, learning of inner MAC entries for traffic that is received on the displayed BVLAN instance, encapsulated by the 802.1ah BEB whose MAC address is displayed will be impacted. Learning of new inner MACs encapsulated by other BEBs is unaffected.
Remedy
Clearing FDB on 802.1ah B-VLANs using clear fdb <bvlan_name> may free up of unused PBB tunnels. If the problem persists, contact Extreme customer support.
Severity
Warning
Message Text
%info% Create Failed - Number of PBB tunnels exceeds supported limit
Message Parameters
Name Type
info String
Applicable Platforms
  • I386 virtual machine switch simulator
