HAL.Card.Warning
Description
An abnormal condition has been detected which, although it is not interfering with the normal operation of the system, may signal that the system or the network in general may not be functioning as expected. The condition may have been caused by an unusual or unexpect circumstance related to some external stimulus.
Remedy
The exact remedy is dependant on the particular situation; but the problem may have been resolved by rejecting the request or performing some default action.
Severity
Warning
Message Text
%format%
Message Parameters
Name Type
format Printf
