HAL.LAG.CfgFail
Description
Configuring a link aggregation group failed in hardware on a chip of a card.
Remedy
This problem is usually due to a failure of accessing a hardware register. The hardware may be in a bad state. The error message gives the detail of the failure. The problem usually can be resolved by retrying the operation or power-cycling the switch or the card in the slot.
Severity
Error
Message Text
Failed to configure link aggregation group %masterSlotPort% on slot %slot% unit %unit%: %errMsg%
Message Parameters
Name Type
masterSlotPort SlotPort
slot Slot
unit sInt32
errMsg String
