HAL.PBB.APIFail
Description
The message shows the API function of the given module that returns an error. The message only provides the information for the debugging of the problem in configuration.
Remedy
There is no rememdy as this message is being displayed for debugging. This log message is intended to help debug problems that may VLAN library or PSI library.
Severity
Debug-Data
Message Text
Failed to %action% in %module% API for %obj% in %info%.
Message Parameters
Name Type
action String
module String
obj String
info String
Applicable Platforms
  • I386 virtual machine switch simulator
