HAL.MPLS.ClrTCAMStatsFail
Description
A TCAM hardware operation failed. The specified TCAM entry's statistics could not be cleared as a result.
Remedy
Try rebooting the associated I/O module. If the problem persists, run diags on the I/O module. If that passes, gather "show tech" output and contact technical support.
Severity
Error
Message Text
TCAM write entry %index% failed (card num %cardno%), ILM %ilmInst%
Message Parameters
Name Type
index xInt
cardno xInt
ilmInst uInt
