A serious problem has been detected which compromises the operation of the system. The system cannot function as expected unless it is remedied The problem may be related to hardware failure or software data corruption.
The exact remedy is dependant on the particular situation; but the problem cannot be resolved without some intervention.
Error
%format%
Name | Type |
format | Printf |
