This message is generated when an attempt to update a maintenance domain fails because no no entry can be found in the database with the level and VLAN.
Verify the correct parameters are specified on the command line. You can also verify the HAL OAM database with the command: debug hal show platform hwa-oam all
Error
Failure updating the maintenance domain because it cannot be found in the database.
Print
this page
Email this topic
Feedback
