Recommend Installing FirmWare Update: Every EXOS release comes with updated firmware that is well tested, however as the firmware update needs to be done manually in-field scenarios may come up where EXOS may be latest, but the firmware may be old.
Running a firmware upgrade with the CLI command 'install firmware' should resolve the situation.
Notice
Version mismatch for %blockcode% on %slotname% , currently(%current_ver%) but expected(%expected_ver%)
| Name | Type |
| blockcode | String |
| slotname | String |
| current_ver | String |
| expected_ver | String |
Print
this page
Email this topic
Feedback
