HAL.Stacking.CfgStkMACAddrInv
Description
The stack MAC address is either not configured, or if it is configured then it is different from the stack MAC that is in use by the master node in the stack.
Remedy
Configure the stack MAC (using the "configure stacking mac-address" command) to be the same on all nodes in the stack, and either reboot the entire stack or reboot the node(s) on which this message appears.
Severity
Error
Message Text
The stack MAC address is not correctly configured on this node. The stack can not operate properly in this condition. Please correct and reboot.
Message Parameters
Name Type
addr MAC
