Use this procedure to view the global FA statistics graphically.
- Click Chassis.
- Click the Fabric Attach tab.
- To view a graphical representation of the statistics, select a row and click the appropriate icon on the top left-hand-side of the menu bar to draw a line chart, area chart, bar chart or a pie chart.
- Click Clear Counters to clear the existing counters, and fix a reference point in time to restart the counters.
- Click Export, to export the statistical data to a file.
- To fix a poll interval, select an appropriate value from the Poll Interval drop-down list.
Fabric Attach field descriptions
Use the data in the following table to use the Fabric Attach tab.
| Name | Description |
| DiscElemReceived | Specifies the number of discovery elements received globally. |
| AsgnReceived | Specifies the number of remote I-SID-to-VLAN assignments received globally. |
| AsgnAccepted | Specifies the number of remote I-SID-to-VLAN assignments accepted globally. |
| AsgnRejected | Specifies the number of remote I-SID-to-VLAN assignments rejected globally. |
| AsgnExpired | Specifies the number of remote I-SID-to-VLAN assignments that expired globally. |
| AuthFailed | Specifies the number of authentications that failed globally. |
| DiscAuthFailed | Specifies the number of discovery authentications that failed globally. |
| DiscElemExpired | Specifies the number of discovery elements that expired globally. |
| DiscElemDeleted | Specifies the number of discovery elements that were deleted globally. |
| AsgnDeleted | Specifies the number of remote assignments that were deleted globally. |
