Before and after you upgrade your switch software, make copies of the configuration files. If an error occurs, use backup configuration files to return the switch to a previous state.
If you use File Transfer Protocol (FTP) or Trivial File Transfer Protocol (TFTP), ensure that you enable the FTP or TFTP server. File Transfer Protocol (FTP) and Trivial File Transfer Protocol (TFTP) support both IPv4 and IPv6 addresses, with no difference in functionality or configuration.
Keep several copies of backup files.
enable
show boot config choice
save config
copy /intflash/config.cfg /intflash/config_backup.cfg
copy /intflash/config.cfg a.b.c.d:/dir/config_backup.cfg
Determine the configuration file names, save the configuration files, and copy the files to a safe place.
Switch:1>enable Switch:1#show boot config choice choice primary config-file "/intflash/config.cfg" choice primary backup-config-file "/intflash/config.cfg" Switch:1#save config Switch:1#copy /intflash/config.cfg 00:11:f9:5b:10:42/dir/config_backup.cfg Do you want to continue? (y/n) y
