![Note](images/note.png)
This procedure does not apply to VSP 8600 Series or XA1400 Series.
Use this task to view IPv6 address statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IPv6 tab.
- To clear IP statistics, select Clear Stats.
- To clear IP counters, select Clear Counters.
IPv6 Field Descriptions
Use the data in the following table to use the IPv6 tab.
Name |
Description |
InReceives |
Shows the inbound packet statistics. |
InHdrErrors |
Shows the inbound packets with header errors statistics. |
InAddrErrors |
Shows the inbound packets with address errors statistics. |
InUnknownProtos |
Shows the inbound packets with unknown protocols statistics. |
InDiscards |
Shows the inbound packets discarded statistics. |
InDelivers |
Shows the inbound packets delivered statistics. |
InTooBigErrors | Shows the inboud packets too big errors statistics. |
InNoRoutes | Shows the inbound packets with no routes statistics. |
InTruncatedPkts | Shows the inbound packets truncated statistics. |
InMcastPkts | Shows the inbound multicast packets statistics. |
InOctets | Shows the inbound octets statistics. |
InMcastOctets | Shows the inbound multicast octets statistics. |
InBcastOctets | Shows the inbound broadcast octets statistics |
InNoECTPkts | Shows the inbound packets with no Explicit Congestion Notification (ECN) statistics. |
InECT1Pkts | Shows the inbound packets with ECT(1) statistics. |
InECT0Pkts | Shows the inbound packets with ECT(0) statistics. |
InCEPkts | Shows the inbound packets with Congestion Ecountered (CE) statistics. |
OutRequests |
Shows the outbound packet requests statistics. |
OutDiscards |
Shows the outbound packets discarded statistics. |
OutNoRoutes |
Shows the outbound packets with no routes statistics. |
OutForwDatagrams |
Shows the forwarded datagram packets statistics. |
OutMcastPkts | Shows the outbound multicast packets statistics. |
OutOctets | Shows the outbound octets statistics. |
OutMcastOctets | Shows the outbound multicast octets statistics. |
OutBcastOctets | Shows the outpound broadcast octets statistics. |
ReasmTimeout |
Shows the packet reassembly timeouts statistics. |
ReasmReqds |
Shows the packet reassembly requests statistics. |
ReasmOKs |
Shows the successfully reassembled packets statistics. |
ReasmFails |
Shows the failed reassembled packets statistics. |
FragOKs |
Shows the successfully fragmented packets statistics. |
FragFails |
Shows the failed fragmented packets statistics. |
FragCreates |
Shows the fragments created statistics. |
